4an fittings for '01 fuel pressure gauge
Drilling and tapping exhaust manifold for EGT thermocouple
Getting Line-X What Questions Should I Ask?
Can somebody tell me the EXACT part number or the like and an EXACT location to buy these blinkin' fittings from? I have checked all over my lil backwoods hic town, the whole dang state for that matter! Most people have no idea what I am talking about, the few that do have no idea where to get them from. One place thinks they found something that would work, but the cost was 30 bucks per fitting, these things aren't that much are they?! I have the stewart warner gauge setup like Steve Laurant, and dual senders, nothing else.
Thanks,
Jerry
Go to the link below, Brandon has forgotten more about this stuff then I will ever know #ad
When you "enter" Brandon's site, click on "directions to my shop" which will provide you numbers to reach him. He set me up with my sender for the SPA gauge.
http://www.mypage.onemain.com/Brandon&Danelle/
White 2001. 5 3500 ETH/DEE 4X4 Quad cab SLT,tow package and camper prep,Husky liners front and rear,DiPricol pyro,boost and oil temp gauges,SPA fuel pressure and temp. gauge,Edge EZ,Psychotty air,Bully Dog stage III injectors,ATS 3 piece manifold,HX40 turbo,4" BD exhaust,4" BD E-brake,McLeod clutch,Mallory 4150 lift pump,Mag-Hytec rear,Go-Rhino grill guard,Lund bug shield,PM tractor utility back up lights,Penda bed mat,365. 8 HP on the dyno and blow by bottle is bye bye !!! I love the smell of diesel in the morning, it reminds me of... . VICTORY !!!
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089608" TARGET=_blank><font color=red>My Truck</font></A>
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089604" TARGET=_blank><font color=red>THE SAINTS</font></A>
I had to get the screwy gauge fittings from a racing supply store. Everywhere else got that "deer in headlights" look.
2001, 3500, 5sp, 3. 54LS, 4x4, pyro and boost on the A-pillar, 165 watts of backup lights, Thomas powered on-board air system, Grovers.
Ditto what BigSaint said. Brandon fixed me up with the same setup. His setup uses a swivel fitting it works great. I had him just send me the complete fitting. He said he would give me part numbers so I could purchase the parts but I was lazy and just had him send me the fitting.
2001. 5 2500HD, SLT, 4X4, QC, LB, Dark Garnet Red, Auto, 3:54's, LSD, Tow pkg, Camper pkg, Amsoil dual bypass w/billet adapter & SS lines, Amsoiled, Smittybuilt side bars, Mag-Hytec Trans pan & Diff cover, Line-X bedliner, Triple SPA's in the A pillar
You can go here <A HREF="http://www.bakerprecision.com/hose.htm" TARGET= >baker precision</A>
They have almost everything from Earls and Aeroquip.
I use a 4an swivel cause you can mount the sender in any direction, i also use the brass 1/8th street elbow cause its has a flat area for senders that arent tapered thread and us a gasket to seal
barry glad you are happy with it, when you get some upgraded lines just pay that fitting forward
later guys
yes the jic fitting is ok and cheap but doesnt allow for alot of flexibility in installing sender
B... ... ... ...
Danelle's Dodge
A <font color=red>WARNING</font> for those using braided stainless steel lines. Braided SS is very abrasive and will saw a hole in most anything with direct contact. Make sure to allow plenty of slack and use harness (P) clips liberally.
I'll try remember to post a photo of the (CNG) fuel filter with a hole in the case from contact with a braided SS line.
That's one of the many maintenance items on my list. Luckily wifey agreed that a new TC & VB is <em>preventive maintenance/em>. woohooo!!
Cheers;
John
