4bt electric fan sending unit
cummins 4bt in m715 is running!
What is this cummins worth?
i dont remember how it was set up when i cut the motor out... ...
does the two prong temp sensor in the inlet neck ground out when it reaches a certain temp? or can i hook positive in on one, and use the other prong for the out to drive an relay for an electric fan????
Its a thermal operated electric switch. Power goes in on one lug, fan on th other. When it reaches design temperature, switch closes and fan runs. I would suggest testing the switch before trusting it on a conversion. Hook a meter or test light to terminals, put switch in a pot of water and bring up the temp. Watch at what temp the switch closes, and opens. The close and open depends on what switch rating you have installed. On a used engine, I would not trust it until I see it work.
Paul
