Hi, looking for info on using a Cummins 4BT in a 1980 GMC 30 series 4 wheel drive chassis. I have picked up some great info looking through the threads and links, but I have not seen any info regarding the front sump, maybe on the 4 wheel drive it won't be an issue, but in my '86 1 ton 2 wheel drive(my original conversion idea) the front crossmember would not allow a front sump. Can the pan be reversed, possibly with a new pickup tube? I am also interested in hooking up to the auto transmision in the truck(turbo 400?) that is coupled to the v8 in it now. The engine I have found is out of an old bakery truck, I believe it has the rotary pump rated at 105 hp set up with clutch and 4 speed and all its accessories, this was a non aftercooled installation, the guy also has a parts engine, complete with accessories and aftercooler plumbing, that threw a rod. Should I stay away from the rotory pump engine? Do newer 4 BT engines have glow plugs?
any input would be great, I know if I wait too long the engine will be sold... ... .
Thanks in advance
Roger
Thanks in advance
Roger
