4bt In 80 D150 Dodge
How About A New Forum For "Cummins" Conversions
4bt cpl
80 MOD DODGE -4BT,105 HP TURBO400 TRANS CAN I RUN THE TRANS AT AN ANGLE ,ENG ,TRANS OUT OF FRITO BOX VAN 8 DEGREE CANT BUILT INTO BELL HOUSING ADAPTER???
I dunno if I'd run an auto at a constant angle or not but...
Swapping that adapter to one off a ISB should be a bolt up propsition. then you could use a getrag, nv4500, 5600, 727, 48rh, or 48re if you have the expertise.
engine adapter plates
Based on two of my conversions, 4bta/getrag and 6bta/getrag the engine adapter plate, starter, and flywheel changed in 1994. If a getrag is used, you will need the early stuff... i have no knowledge about the autos.
I got a little freaked out when I realized there was a 7* tilt on that adaptor. It took me a little while to calm down. I ended up splitting the difference between engine tilt and transmission tilt. No one ever notices and it all works fine.
