4bt turbo exhaust flange
will a 1994 Chevy 3500 Crew Cab 4x4 SRW have room for a 6BT?
Small Cummins 270 on Ebay
what is the actual name of this piece. where can you buy them? are they the same as a 6bt? it is the flange thats actually on the exhaust pipe that is held flush against the turbo housing and a clamp holds the 2 together.
It sounds like you are describing the 'v-band flange/clamp' on the turbine discharge side of things... .
On the 6BT's - this is a standard 3" v-band flange/clamp... .
Matt
