4th Gen Lift pump reliability question
New fuel filter on 2013's near tank
2013 Floor Console
My 2013 3500 is my 6th Dodge Diesel pickup. One of the common issues that I had with all of them is lift pump reliability issues. I had installed FASS pumps on all of them. How are the lift pumps on the new trucks doing? Is there a failure issue?
It also must deliver a good bit of fuel, since the factory power rating is 385 HP.
The pump the debuted in 2005 has adequate flow for 385hp. The QSB480 only needs a 50 GPH pump, with a 25 GPH return rate, to make 480 hp. From what I can find the in-tank pump is around 50 GPH at 5 psi. When I tested mine it was near 90 GPH at 0 psi.
Thanks for the information. My plan is to NOT change anything on this truck unless there is a failure, or something to be prevented.
