The way they mount is different the 06 has cut outs in the rocker for an oblong nut plate to slide in a cut out the 4th gen mounts with rivnuts with a hex hole punched into the rocker. Both also have bolts through the pinch weld as I recall. I can't tell you if the angles are the same. If the price is right give it a shot
