Hi All, so I have a 2015, 2500. My power windows, driver and passenger will roll down for no reason and will not roll back up using the switch. It happens going over bumps, static shock in cold weather and if I do roll them down using the switch they will not roll back up unless I pull the drivers door mod 30A fuse and plug back in, and that will let me roll them back up. But the problem keeps happening. The only way to get them to roll back up is do the fuse trick. I have tried holding them in the "up" position for 10 seconds and in the "down" position for 10 seconds to reset them. No luck. I see that there is a door mod and I am wondering if that is my problem. The back windows work fine. The passenger window does the same thing as the drivers door. Every time they roll down, I pull over and pull the fuse, pop it back in and roll them up, it's a one shot deal each time they roll down.
Thought? Thanks!! Dealer was no help.
