Recently had torque converter replaced and I hit the road. I am now in Ky and need 4wd, it is snowing. At first I just needed to back out of tight spots I get into because I have 4WD. The shifting felt imprecise but when the 4wd light came on I thought all was well but no power to the front wheels, --- 4lo works.
I believe what is happening is that somehow the part that shifts from high to low is being moved too much in the 4hi shift because, one of those times when I thought i had shifted to 4hi i Had no power to any wheels as occurs as you shift between hi and lo.
My service manual is at home. I have never looked at the shift mechanism so I do not even have a picture in my mind of what adjustments there are. Is there some kind of adjustment in the linkage to the shifter lever external to the transfer case that I can adjust? And if so is it something I can do without my shop manual. I am at my son's house for the next few days and can get in a garage with lights heat etc to work on this. It is going to be snowing when I leave for Ala Monday and would sure like to be able to travel with 4WD when needed.
Before the torque converter replacement 4WD had always worked with good feel so I am thinking it is something the tech messed up on in the reinstall.
