I started a thread about doing a 2 low conversion a few weeks ago, and it died after my last question.
So we will try again.
I left off at "What do the vacuum hoses (red and black) do?"
I went out and looked at mine, and in 2 hi the red hose has vacuum and the black does not. When shifting into either 4 hi or low, the black has vacuum and the red does not.
The valve that I have has 4 ports on it (A flows to 1, and B - 2), when activated the the flow is A - 2 and B - 1) So if I am thinking correctly, if I have the red from the transfer case hooked to A, and the black to B, then the hoses to the axle 1 = red and 2 = black, then when activated after shifting into either 4wd option, the vacuum would be switched like it would normally be in 2wd, correct?
Now the transfer case is driving the front drive shaft in 4wd, and the vacuum with the valve activated keeps it in 2wd, I should have the option of 2 low now correct? Is there anything that I missed?
When to activate the valve, before or after I shift the transfer into 4wd, or at the same time?
If the front drive shaft is putting power to the front axle, and the vacuum is running like it would be in 2wd, is any power going to the axle, or just one half (3wd)?
