4wd Rattle
Fuel tank leaking.
3rd Gen CB Radio Mount
Several weeks ago I noticed a slight rattling noise while in 4wd. Mentioned it to the mechanic and he said it was nothing. After a weekend at the cabin and some snow fall, spending a lot of time in 4wd the rattle has become significantly worse. Also now there is an intermittent whistle/chirping noise in 2wd. Haven't had an issues with 4wd performance just loud. Any suggestions? Recently had 4 shocks and ball joints done. Truck is stock other than airdog II. thanks
The 2003 2500 does not have cv joints they use u joints and it sounds like you may have a gear rattle from the transfer case when engaged in four wheel drive.
I think the confusion with the Cardan joint comes from the fact that the front DS uses a "double Cardan" joint, which is effectively a constant-velocity joint, even though it cannot operate at the angles of a true CV joint.
