The 95 has about 2.4k miles and ticking noise from right ft. wheel. Found a chunk missing from the cast yoke assembly that is part of the section that has the 4 bolt holes in it. The part that bolts to the wheel. ( not sure what it's called) so i think that is the area that needs repair. Trying to find info on that part #, a good company for replacement u-joints, and to go with grease fittings or not. I was told the solid u-joints are stronger? I looked at some u-tube's on how to do the job but I am not having much luck on finding what threads or what TDR mag's to do more research before I get into this job. I would like some of your experience TDR members. Thank you. ken
