4wd vs. 2wd wheels?
ABS/ Brake Light comes on and stays on
Differential oil change questions
Have the opportunity to buy some Alcoas from a 2wd truck... is there a difference in wheels from 2wd to 4wd?
97 2500 CC 4x4 3. 54, 5spd, Green, #12 plate, 4inch open exhaust, 235/85 Michelins, RS 9000's, PrimeLoc, Red Tops, TDR cloisonae grill badge!
They will fit if the backspacing is less than 4. 75", that is the backspacing of the factory wheel. If the backspacing is not enough, say 3. 5", it will shift the weight and put alot of stress on the frontend components, and stick the wheel outside the body (if wide enough)
What size are they? and what model (classic, challenger)? If you goto M/T website you can check the specs of the wheel if you know the size.
To make this long answer short, I'm sure they'll fit (none of the M/T wheels have a backspacing greater than 4 9/16"
Ryan
