4x2 suspension maintenance
Will a Ford Cap fit a Dodge?
CIPA Mirrors & BD STEERING BOX STABILIZER
dlmetzger
Is there any maintenance required for a 2008 3500 Ram 4x2? This is from the owners manual:
At Each Oil Change
² Change the engine oil filter.
² Inspect the exhaust system.
² Inspect the brake hoses.
² Inspect the U-Joints (if equipped) and front suspension
components.
² Check the automatic transmission fluid level.
² Check the manual transmission fluid level.
² Check the coolant level, hoses, and clamps.
² Lubricate outer tie rod ends (4X4) models only.
² Lubricate Front Drive Shaft Fitting (4X4).
The manual from the maintenance schedule also says (w/out the 4x4 exclusion):
Lubricate outer tie rod ends. X X X X X
It's quite likely that the 2wd variants use the same tie rod ends. Just check to see whether you have grease fittings there, and if so lubricate them.
Ryan
