Nothing personal but it is simply a bad idea and any advice to try it is not doing you any favors. The frame is too light and the front and rear axles will not hold up, not to mention your 2wd transmission will not bolt up to the transfer case and that transfer case is not going to hold up either. I personally would find a different truck if you want a 4wd.
The Cummins trucks had Dana 60's in the front and Dana 70's in the rear and the frame was heavier, as was the transfer case, heavy duty drivetrain required for the power/torque involved.
