Archived 4x4 - diff ? trasfer case ?
Archived power steering leak
Archived Vehicle Shut Down, Can't Restart
here's the deal I'm out plowin now
when I shift it into 4hi ( didn't try 4 low yet )
I hear a banging noise kinda like a u-jint going
but it's not constant , maybe 1 klunk every
5-10 seconds
anybody have a clue ???
here's my cell 203-521-4942
today really sucks :mad:
thanks guys/gals any help is greatly appreciated
sounds like a u-joint to me... maybe a carrier bearing on the two piece drive shaft...
does it do it in 2X4 mode or just 4x4... if just 4x4 check front shaft , but look at all of them
also there have been issues with the snap ring at the back of the tail shaft out of the xfer case... look there also
FYI... . fill in your info on your truck in the sig line or post it when you ask for help. .
I would check the CV joint in the front drive shaft. It could have excessive wear, causing the clunk. It could also be a front U-Joint, but it would do this in both 2wd and 4wd. Is the clunk comming from when you turn the wheel? It could be a ball joint going bad.
-Rich
