Recently picked up my new truck and am curious if this is normal. After I tried testing the 4x4 electronic shift feature, I found that the vacuum continued to run even after I had shut the truck off and restarted it. It seems to shift OK in and out of 4x4. But once I move the switch and the vacuum turns on it will continue to run. I haven’t fully troubleshot the conditions yet, but I believe once I give it a bit of throttle it shuts off but once I let go of the throttle or come almost to a complete stop it turns on again. Eventually if I don’t use the 4x4 switch again it will stop running.
Also, would there be any connection to this vacuum controller and the exhaust brake? When my exhaust brake kicks in I hear it in the exhaust but I also here the vacuum running again. Once I get slow enough to where the exhaust brake turns off the vacuum also turns off (assuming it’s not running due to me shifting the 4x4 mode).
Ken
Ken
