4x4 Indicator light??
How do you keep your rocker panels clean?
Traction Bars....
Is there a fuse for the 4x4 light?? Mine does not work when shifted into 4wd. . the 4x4 does work though... Someone know which fuse or what the cause could be?
-Chris-
Maybe loose wire on sending unit, road rash at sending unit. mine was on top of right front axel tube. replaced sending unit (cheap) light came back on.
