4x4 POSI-LOC ™ SYSTEM
4" muffler survey
turbo
I saw this new product in a J. C Whitney catalog I recieved today. No pictures on their website yet. This may be a good solution for us with "tough to shift" transfer cases #ad
. I will search to web for more info. It almost looks like a PTO cable like mechinism.
For 94-00 Dodge Ram 1500-3500 4WD Trucks
Easy external installation in 60 minutes or less -- no axle disassembly!
Lock up the 4-wheel-drive instantly in any temperature from inside cab... whether you're moving or not.
With 4x4 Posi-Lok engaged, you'll always have complete control of 4x4 action at your finigertips... until you decide to disengage system.
No need to stop truck to lock up system.
4x4 Posi-Lok replaces original 4WD actuator in your truck --takes only about an hour to install. For all 94-00 DODGE Ram 1500-3500 with Dana 44-60 CAD (Central Axle Disconnect) axle.
Better than Original Equipment 4WD Unit!
Instant lock-up.
No delays caused by cold outside
temperatures.
Won't disengage when you turn off ignition or are submerged in mud, water or snow.
Always works then you need it.
Not prone to failure like electric or vacuum units.
No need to roll vehicle forward before 4WD engages.
Allows use of 2WD (low range).
Allows differential assembly to rotate on bearings when locked up-minimizes wear.
J. C Whitney P# 07DV5918A... ... . $179. 99
Signature went with the "crash". . out in cyber space somewhere...
[This message has been edited by HEMI®Dart (edited 02-14-2000). ]
Hemi- the Posi-Loc converts the vacuum (or electrical)actuator on the front axle to mechanical- if your transfer case isn't shifting properly I don't think this unit will do anything to help with that problem.
Bill Lins Wharton, TX 98 2500 QC SLT,12 valve,NV4500,3. 54 LSD,Manik grille guard,K&N filter,Amsoil everywhere, Reading aluminum utility body and bumper,Optima yellow tops
Hmmmm... . minimizes wear by allowing more parts to rotate... . that's a novel theory. #ad
Mike
[This message has been edited by Mike Carter (edited 02-15-2000). ]
