Just installed a posi lock cable to replace my frozen Vac CAD. A few questions about normal operation.
First off, when I was installing the cable on the axle, the collar that slides back and forth to lock the axle would not fully move over into the 4wd position,
like the gears were just a little mis aligned, ( I could not move it with my hand).
I installed the posi lock with the collar and fork in the 2wd position hoping all would be well.
The cable works fine but it takes some doing to get it to go in and out. . going a little in reverse or turning the wheel back and forth, I tried to engage the cable while the truck was rolling and it made a grinding noise,
did not try that again.
I have read other threads about it taking some getting used to, just want some feedback from others experiences.....
Thanks
Thanks
