i had one on my 98. 5. wrked great but hard to engage till ya got used to it. release pressure b4 ya engage it. make 100% SURE that it is pulled all the way. as dirctions say the last bit of cable travel is VERY importnt. follow directions completly.
Follow these simple steps and you're in control
ENGAGEMENT
Relax the throttle - no acceleration or deceleration.
Shift the transfer case to desired 4x4 mode.
Press the button and pull the cable into full engaged position. (Light on-off throttle action will help align gears for smooth engagement. )
Release the button.
NOTES
2WD Lo-range–Place the transfer case in 4WD Lo range, but do not engage the 4x4 Posi-Lok system. Warning: Do not apply excessive torque in this mode.
DISENGAGEMENT
Place transfer case in 2WD mode.
Press the button, push the cable into full disengaged position, and release the button. If moving, light on-off throttle action will help to relax the drive train.
Disengagement may be easier with some models if the vehicle is stopped and put into reverse for a few inches while pushing the cable in.
it took a few times for me to get hang of it but aftr that, easy to engage. as was mentioned lite on off throttle action will help engagement. and remembr,i cant stress enuff that the last bit of travel in cable be important for positive engagment
if my new dually had the vacumn disconect id be instlling the 4x4posi-lok
http://www.4x4posi-lok.com/
