Engine/Transmission (1994 - 1998) 4x4 Shifter Rattle
Engine/Transmission (1994 - 1998) new member ideas?
Engine/Transmission (1998.5 - 2002) Got Boost???
If I remember correctly there is a TB on this. it involves using a pry bar to bend a bracket? a bit as the tolerance is so close now the vibration from the CTD causes it to hit against the base and causes the rattle. If i find the TB I will post it. Cheers.
