Hi all,
My transfer case is leaking, and I finally found out it is building up internal pressure and spitting out from the small rubber plug on the top of the T-case. I had asked about this in someone else's thread a few weeks ago, and someone responded that my vent tube was plugged and I just needed to clean the end cap off so it could breathe again. At least I believe this is what's happening. I replaced the rear output seal in the T-case about 4 months ago, and it was in fact leaking then, but i9t is not the culprit this time.
Well, I have looked all around the beast, and the only thing I can find coming out of it is what appears to be an electrical wiring harness. I follow it and it runs up into the engine compartment right along side the "T" in the return fuel line right at the rear of the engine block.
When I remove the rubber plug in the T-case, and wipe off the case, I don't see any leaks or drips for a couple weeks, but then it comes back. I am about to leave on a hunting trip to northern Utah, and don't really want to have any problems...
Can anyone lend any hints as to exactly where the darn vent tube really comes out?
Many thanks,
Tom
Many thanks,
Tom
