4x4 Wheel Alignment
Funny problem ... had to laugh
Drive train noise/slack
I remember that there were a few posts awhile back discussing wheel alignment on a 4x4 (specifically a 3500). Can this be done at any specialty 4x4 shop or is there a special alignment tool that only the dealer has. I am getting accelerated wear on my front tires only (which I think is normal for my mountain commute), but one side is definitely wearing faster than the other. Any help would be appreciated.
I also seem to recall that somebody had posted tighter specs than the factory calls out which should be used, and I am hoping that I saved those away on my home computer somewhere.
dresslered,
Try looking at alignment or pulling to the right. I just had mine corrected several months ago... but I can't remember the specs. They had to replace the ball joint with an off set one.
Frank
I believe these are the numbers you're looking for. These are from another's post that I copied into my files. I apologize for not being able to give full credit to the originator but I didn't copy the handle. It was an excellant post.
... ... ... ... ... ... Left Wheel... ... Right Wheel
Caster... ... ... ... ... . 3. 2... ... ... ... . 3. 5
Cross Caster... ... ... . -. 3
Camber... ... ... ..... -. 10... ... ... ..... -. 10
Cross Camber... ... ... . 0. 0
Toe - standard specs, (maybe a little out if you tow a lot, they will pull in as the front end lifts up).
Thanks guys! I had also archived the article and just found it. The previous specs are correct. I believe that we can thank David Fritz for posting it at his site. Also, it appears that the original artical was written by Brent (ASE Certified Gold Certified Chrysler tech).
