5.9/360 1500 4x4
jetta diesel inj pump
2008 Dodge Charger
I am looking for some parts for my 360.
The first part is the plastic crossover tube on the rear of the fuel rails. It connects the 2 rails.
The other is the sleeves that go into the head to protect the spark plug boots from the heat of the manifold.
I have searched the net with no results.
Mark, I'm not sure if you can get the tube seperate. May have to buy the whole rail. :eek: Very expensive IIRC.
The 360 that is in my Van has just a standard heavy duty piece of fuel line with band clamps on the cross over line between the two rails. Its only under ~20-25 PSI, so I wouldnt think you need something to special. I would think a well re-inforced quality rubber fuel line from NAPA or such should be fine.
As to the spark plug boots... . might be a dealer only thing, and good luck. Dodge has discontinued alot of stuff from older trucks. Bunch of BS, but I cant get something as simple as the possitive cable from the battery to the starter from Dodge for my van. The damn thing is only 10 years old and almost every part is discontinued!
That's what I was thinking of doing. They make regular fuel line, and injection feul line. Double clamp on both sides and hope it works.
The sleeves I have found, $18 a piece! :-{} I think I'll try making my own...
