5.9 370 hp
Pulled a 99 PowerPoke out of the mud last week!
Hey Shrimpy, check it out
Picked up a brochure on cummins marine engines today. 370B, 370 hp, 355 rated hp. Anmd that's at full load all the time! I wonder if the water cooled intake cahrge cools that much better than air-to-air allowing them to keep EGT's low while shoveling in massive amounts of fuel?
http://coffeewithJesus. homestead.com/web1.html 89 1-ton, Amsoil System 3000 5-30,K&N air filter, cleaned-up exhaust, Dynomax straight-thru, rebuilt pump, 12cm wastegated turbo, thermostaticly controlled twin 14" electric fans, intercooler, modified 518 OD transmission, Gear vendors OD controler, R-134, louvered fenders, 93 aftermarket smoothe grille; 78 35'Avion, 93 Lance 900 slide in with generator and power jacks. Jesus saves!
its much more than the aftercooler, 15. 1:1 and cam are just a start, I'm sure there is more for the continuous duty cycle of the 370's.
