5.9 cold start trouble
The Search for the Best Serpentine Belt
Transfer case leaking again
The mornings have been between 30-40 here and my truck will barely start.
My electric gauge is within parameters, my batteries are new, no codes..
Any thoughts?
This past summer, my truck starter cranking over slowly. I suspected old batteries, but it did the same thing while being jump started. I pulled the starter for a rebuild and it ended up having a brush problem. It was gone through by a local rebuilder and works fine now.
You can perform a voltage drop test to pinpoint your problem but as others have mentioned, I suspect it's your starter from your description.
