5.9 engine vibration
topcret
engine idle
I have an 05 3500 with a vibration at idle and low rpm g56 transmission, could it have a broken crankshaft or maybe just a problem with a bad dual mass flywheel? and ideas would be helpful, truck has 106780 miles
thanks Scott
Thanks for the help, does anyone know about the broken crank problem, is it only 04 that has a problem? Thanks Scott
replaced clutch assembly with new flywheel included, vibration is now gone, cluth works very smooth. I used the perfection clutch as advertised in tdr
thanks Scott
