Joseph Donnelly said:Cast iron was good enough for Sickly to make 800 hp.
hdm48 said:I hate to be the nay sayer here but, the whole point of a header is to equalize the back pressure, control the back pressure, and doing so cause the power/torque curve to move to your desired rpm with respect for the increase in CFM.
Not to mention the heat loss due to the thin wall tubing.
A modified stock or ats is the answer.
Mark_Kendrick said:If you want to keep heat in use ceramicating or header wrap. To think that a turbo motor won't benefit from more air in and out of it is ridiculous.
Just because sickly didn't have it nobody should???.
Joe, when are you gonna make some power BELOW 3000rpm? I can still build a 400hp truck to SPANK sickly at the track. .
The prices are way steep. .
CDegner said:It will benefit from more air in and out but a header on our trucks is not going to do it for you.
Who said that? Hmmm, cast iron. Joe might be on to something. Funny, none of the other high HP 24V trucks around here are are running that contraption either. Maybe they do around your neck of the woods. Cow Town has been known for some unusual things in the past.
and my daddy can beat your daddy up![]()
Hey, what do you know ... we agree on something!![]()
:-laf Carl
