5" exhaust installed
It's like driving a whole new truck...
05 loss of power in bottom end
You can check the pics out HERE . I cut the flange off the stock exhuast and welded it to the reducer and then ran the rest out the back. I found out I need another elbow to bring it out the side, but where it is isn't very loud. I am also going to raise it a little, it's a little too low, but it'll be ok for the next couple of days. It's got a much deeper tone than stock and is suprisingly quiet at 65-70, but at about 1500 rpm in 4-5-6 gears WOW does it rumble. It'll rattle the change in the center console. The turbo spools up quicker and with a stock wastegate and the TST on 4-4 I can hit 32 lbs now. EGT's seemed to have dropped a little, but nothing to drastic.
EDIT : I know it looks like it hits the frame rail in the first couple of pics, but it does have about an inch of clearance.
can you see it when youre looking at the side of the truck? it looks like it sits a bit low. woohoo 5" nothings better!
Ian
Yea, you can only see the bottom tip of the resonator, but like I posted earlier, I'm going to move it up a few inches. Ordering the elbows to fix that on Monday.
