I got to thinking about my fuel pressure and like everyone else, The more I thought about it, the more I worried. I decided to just make a quickie gauge to check my overflow valve. I found a pressure gauge, internally dampened, liquid filled, stainless case, vibration proof, that was only 1-1/2" in dia. I made a double banjo bolt that includes the origional bleed screw on my lathe. I also turned and tapped a ring for the gauge. It mounts firmly right on top of my fuel filter housing.
It's probably not as good as a gauge mounted in the cab because you cannot see it while under load. But it took me all of about 5 min to install it. Total cost, about 35$ I can make up some more if anyone is interested.
My idle press is about 17 and 2500rpm is about 30. Does this seem about right??
