#5 plate+GSK+370's+191DV's=SMOKED CLUTCH
Warning to All: Liftpump dies again!!
Got My Truck!!!!
Spent this Saturday afternoon bombing my hunting buddies 94 Truck. We made a lot of changes all at once and it worked out well! I warned him that with all these mods he will be in the market for a new clutch. Sure enough he roasted his stock clutch on his second run up our local test hill. :D :rolleyes: :D :rolleyes: :D
A Southbend clutch and an HX40 are the next planned modsOo. Oo. Oo.
dont ya just love it!
I recomend getting the flywheel cut at a real machine shop and dont forget the pilot bushing or bearing...
and that frame rail will require a good spread to relieve the trans crossmember.
have fun!:D
you probably know this but others may not...
Rebel, which is your local test hill? What were the results? I'd like to test mine on the same hill and compare stock to upgraded. I know your killing me, but by how much compared to the upgrade costs. Just a friendly comparison. Later.
Rebel, Thanks for letting me stop by. You definatly have a sweet truck! Guys, his truck on the local test hill: 75mph, mine: 68 mph. Not bad for stock. At least as far as I know! Can hear the turbo much more though! The previous owner must have tossed the silencer ring. Guess that answers my dilema of getting rid of it or not. :D
tcpdrafting,
The pleasure was all mine. You've got a darn nice truck that is just waiting to be bombed.
Oh buy the way, I was indicating 77 at the upper marker which corrects to 79. 5 due to tire size, and then there is that 546 lbs. of extra fuel I'm now packing..... :p;):D
Slipping Clutch
I’ve read numerous threads on smoked clutches and it leads me to wonder, why are these Dodge / Cummins trucks are so hard on clutches? I drove concrete trucks, dump trucks and lowboys, the concrete trucks were early late 60’s and early 70’s trucks and horsepower was an option that they didn’t have. These trucks had 160 to 300hp and grossed 56000 lbs. What they lacked in horsepower they made up in gearing the early trucks had 5 speed mains and 4 speed auxiliary transmissions, the newer trucks had 10 speed Roadrangers. I never had to replace a clutch on any truck I drove. The concrete trucks did a lot of stop and go driving while moving around a construction site. I talked to a friend of mine who drives a dump truck with a pup trailer that grosses 105,000 lbs, he now has 380,000 miles on the truck and it still has the original clutch. He drives for an asphalt company and also does a lot of stop and go driving. It would seem that more horsepower and torque would enhance the life of the clutch since the clutch could befully released and the truck moving before you had to add power. The worst thing you can do to a clutch is add power before the clutch is fully released. I have never driven a diesel that wouldn’t start out at idle if it was in a low enough gear. Are Dodge trucks not geared low enough to start out without slipping the clutch? I’m just curious? Jeff
Most clutch problems area direct result of increased horsepower.
The stock clutch can usually handle horsepower up to 300. After that, they tend to slip.
Like mine.
Mine slips after I shift into 3rd. After the clutch is fully released, if I floor it, up goes the RPM's.
JeffMic,
You’re not really comparing apples to apples. The trucks that you are speaking of normally come with Mack or Eaton fuller or Spicer or Cummins drive trains. These types of trucks come with 14" or 15 1/2" double disc clutches with 4000lb plate loads. Others like in the new White/Volvo trucks are coming with 17" single plate. Your truck has a 12 1/4" single plate clutch, now couple that with 400+hp /1000ft lb+ torque and you have a clutch that won't hold.
One thing that all should remember, your clutches are NOT bad clutches. They do what they were designed to do and do a good job. Many of you who do not increase your horse power (GOD FORBID) :D the clutches will work well.
Keep adding that HP;)
Peter
