If you're gonna order one, consider giving Joe D a PM about a #100. I crafted the design, Joe built it & numbered it. What I wanted is a #10 on the low & #0 on the high end.
It's not as obscene as the #0 on the low end but gives you the #0 on the top end.
I actually believe acceleration is better with the 100. Fueling isn't as gross, maybe that's why. However, EGT IS way less.
What you'll notice with the #0 is you build EGT way fast & it doesn't go down until you get outa the throttle. Basically, you can't use the top end of the #0 because of all the built up EGT. Thats in a 215 pump with Mach 3's. With the 100, gobs of fuel is there on the low end but not the EGT. That way, you go into the high rpm range with less built up EGT. That was my thought in the design & hey, it worked. Oo.
