I had a SBC Con FE installed about 1 year and 15,000 miles ago. When I picked the truck up, I immediately noticed it went into gear harder. It would move the truck forward a little bit with the clutch pedal to the floor and then stop. I complained to the dealer and they said the clutch was fine, and replaced the top plate in the transmission. That seemed to help very little if at all. I just got used to shifting with reving the engine up and double clutching as necessary. Well, this past weekend it started getting worse and after removing the floor mat, it seems to have improved. It works good about 80% of the time. Still sometimes I can't get it into 1,2 or R. One time it even was very hard to pull it out of reverse.
Clutch pressure feels the same. Can't see any visible leaks. Fluid is topped off. Clutch has always engaged about two inches from top of clutch travel.
Any help would be greatly appreciated.
Thanks,
Dan
Thanks,
Dan
