I recently pulled my 2wd nv4500 to do a rebuild. The rebuild went well. I put in new bearings and synchros, along with a couple gears. With the trans on the bench i put the newer style top cover off of a 96 and up and shifted through all gears smoothly and worked correctly. I installed the transmission. I started the truck and put in reverse to back out of the shop and truck acted like the trans was bound up and wouldnt go. I put in neutral and let out the clutch and same thing, bound up and stuck in some gear(s). Put a load on motor but no movement. Anyone ever experience this before?
