Engine/Transmission (1998.5 - 2002) 5 speed doesnt want to go into gear
Engine/Transmission (1998.5 - 2002) RASP and Walbro 392
Engine/Transmission (1998.5 - 2002) Fuel Pressure Issue
as the title says i doesnt want to go into gear with the clutch push in, it will but you really have to force it. once in gear it drives ok the shift seem to be notchy though. if i push the clutch in at a stop sign, with it in gear still it doesnt want to roll or creep, it like it is completely disengaged, until you take it out of gear and try to put it back it. oh yeah shifting without the clutch is smoother. i have SBC hydro upgarde in my garage that i havent installed yet maybe that will fix it. it was kinda wierd the was no warning, it just happened.
Clutch is not disengaging completely.
Either the clutch needs bleed ( hydraulic) , adjusted, or has a warped disc.
