5 speed oil level?
Quadzilla box
install 5'' exhaust
Swayse
There I was, filling my beast with diesel, when I look under the truck and see an oil spot. "Aww, it's gotta be someone else's oil, my perfect truck don't leak" I says " just a loser's oil spot that doesn't take care of his truck the way I do". Well I look anyway, "oh, crap" I says.
There is oil running down my transmission from the top. I drive home very carefully, keep waiting for my transmission to just lock up and call it good. After awhile of looking with my flash light and mirrow, I spot the problem, shift tower is loose. I have never had the thing off, thought about a short shift, but didn't want to rip into my truck. Ok, I rip into it and find the two of the bolts were loose. No big deal, I clean it up, put some black RTV on it and put it together with lock tite.
Ok, now I go to add oil. Take out the fill plug and oil comes out. Well I got some weight on the back of the truck, so I'll just jack it up. So I jack it up in the back 2" higher than stock ride height and oil still comes out. I look at the transmission and it still pointing down.
So do I level the truck to check oil, or should I level the trany? My guess is that the trany was filled with oil before it was installed on the truck, so I should level the trany. But I don't wanna run it over full. Split the difference?:confused:
Level the truck, more or less, not extremely critical. Just don't do it on a San Francisco hilly street :D Fill the NV4500 five speed with Castrol Syntorq not some generic stuff off the shelf, to the bottom of the fill hole.
Thanks.
Talked to another Dodge guy yesterday. He had the same thing happen to him on a 2002 Dodge with the 6 speed.
