My search attempts yielded little info on the 5 speed shaft nut. Can someone bring me up to date on the fix for this problem.
A) Outline the procedure as i will be doing the operation myself
B) Where can I procure the parts required and what is cost?
I'm not even sure I need to do this. As I read the TSB it did not apply to my ride. Do all the 5 speeds have this problem? Or is the TSB correctly aimed at only a certain production run? I tow about 13k and do not need a failure of this sort with my family in the middle of the desert.
That brings us to the next question... Does a six speed swap in?
And finally... . Can an exhaust brake be used to warm the motor up faster?? Is there more than one fuel filter on these things... . maybe a full flow in addition to the cannister?
After all those questions I should probably provide some info too.
105,000 still on first lift pump with good pressure. Have diablo puck and Jardine 4" exhaust only, so maybe i'm not taxing the system.
Thx
Thx
