6 speed swap
In my opinion this is not worht it for a common rail truck. I did it in my 97 and it really benifited from the close ratios. But remember the 12 valve engines have a distinct torque peak. The commom rail engines have a flat torque band. They rev easier and maintain peak torque higher that the 12 valve engines. That said you need a different crossmember/ transmission mount, new flywheel clutch assembly, extend the backup light switch wiring, different shift tower/boot. Also remember you need to shift through 5 gears everytime you take off instead of 4 gears. Keep in mind the top and bottom ratios are the same for 6 speed vs 5 speed. 6 speed shifts slower, bigger gears. My 0. 02. Ken Irwin
