50 pin connector woes
Coolant Recommendations
ABS and brake light ON
I installed my e brake today allong with boost and EGT gauges. everething was going great until I got to the 50 pin connector attachment. First, I nicked one of the adjasent wires ( No. 10 orange I believe) and then I could not get the connector to hook back up. The front side wanted to go on, but the back half did not want to seat down eavenly. I did not want to force it and it was getting dark, so I quit. PLEASE help with reconnection sugestions
Y2K 2500, QC, 4X4, 3. 54LS, ST, 5 speed, SWB, 12 Disk JVC CD
[This message has been edited by Posm (edited 12-16-2000). ]
I have seen them use WD40 out in the field when putting harness and ECM's togather. We have some special stuff we use out on the line for the ones that dont go togather easy. I will see if I can find out the name of it for you. If you cant wait try the WD40 route.
Always ready to help!
2000 2500 Red Sport quad cab, 4x4, K&N, DDI's, straight piped, boost, pyro and fuel pressure gages, Hot Power Edge, mean looking set of 33. 5" tires, Snap On diamond tool box, Marine Corps window sticker, Semper Fi!
1972 340 Cuda'. Original tripple Black, 340 car w/air. Good clean car, super stock springs, Weld Prostars, shaker hood, strong 340 with a 727/4000 stahl, 4. 56... . Bombs away!
NRA Life Member. http://www.geocities.com/chadsheets
there is a possibility that you bent some male pins when you disconnected it an they are not slipping into the female pins. try starting the back side first and then work it to the front. You might want to try some dielectric silicon grease ( used on gassers for distributer and spark plug boots ), this will slic it up and prevent corrosion of the pins
[This message has been edited by JNutter (edited 12-16-2000). ]
