50psi guage, Low Readings
Propane with VA or PE EZ box
Amsoil ATF+4
Go ahead and say it, what took you so long?
I just got off my lazy butt and installed my 50psi Ultra-Lite gauge and am getting no measurable boost until about 1900rpm's. I thought that the 1/8th line was kinked but it wasn't. I installed the fitting in the square intake tube and used pipe dope for extra insurance. This is just sitting in the driveway reving it just to test the guage itself.
I was gonna wait to road test it when I take the youngins trickin',but the old bag said I shouldn't drive "THAT LOUD THING" and disturb the neighbors any more than I already have. She said that they might not give our kids any candy. I forgot about the other night with me sitting on my remote and sounding off the alarm with the Grovers wailing at 1:00am #ad
I'm gonna give it a whirl in a few minutes. I'll let ya know something when I get back.
<font color=blue>
'99 2500HD Quad Cab 4x4, Intense Blue Pearlcoat, Fully loaded w/Agate leather interior, 5-speed, 4. 10 Limited Slip, Skyjacker Leveling kit, Heckethorn Nitro 9000 shocks w/dual End to End steering stabilizers, 35x12. 50x16. 5 BFG/AT KO's on 9. 75x16. 5 Eagle 589 Aluminum Wheels, 9004 Cool Blue's, Silencer Ring removed, Fog Lights relay pulled, No muffler, No resonator, 4" straight pipe, Northwest Customs Stainless Steel Rocker Panels, Steel Horse Stainless Steel Nerf Bars, K&N Filter,Custom POWEREDGE W/HOT Programs 60/80/100+HP, Grover Air Horns, Autometer Ultra-Lite Gauges.
I just got back and boy do I feel stupid! Forgive me please, I haven't had the breakfast beer of champions yet.
My boost readings with the Hot Edge in the different levels were:
Level 1: 28psi
Level 2: 30psi
Hot 3: 34psi
I haven't even munked with the boost elbow set screw yet. I'll probably go out and crank it in to just see what it does for the boost.
I'm sure glad I got the 50psi guage! #ad
WOWZY:
Tell me about the Grover install. Was it easy? Where'd you put the compressor/tank/horns? Wired directly to the wheel, horn button, or separate switch. How do you like 'em? #ad
wowzy , i did the same thing when i installed mine , i disconnected the hose and could feel air blowing out , but not enough to read on the gauge ... i have isspro ... with no load the turbo is hard pressed to do any work . having an auto impaired ram , if i put it in gear and stand on the brake and bring up the rpms it will get up to 40 psi #ad
Sasquatch, I had a link to the complete install illustrated by pics. I can tell you that you'll be best to mount the compresser under the pass. side battery tray and the tank under on the frame, near the bed. I wedges the horns up inside the bumper and strapped them to the cross frame. The only thing that I don't like is the shorter of the horns sounds off before the longer one does. I have been meaning to put a pressure gauge on the tank to see if the compresser presser switch is cutting off a too low a pressure. I wired the solenoid to one of the existing oem horn cables,so that I could activate them from just hitting the steering wheel.
Anyone notice their ultra-lite 50 psi guage needle not returning to "0psi" after the engine is shut off? If I flick it with my finger,the needle drops back to "0". Do I need a replacement gauge?
good question illflem , since i don't have a transmission temp gauge as of yet #ad
i would have to say boost ??? , i'll know in a week or 2 ... #ad
