Engine/Transmission (1998.5 - 2002) 53 block again
2nd Gen Non-Engine/Transmission Fuel line and fittings at tank
2nd Gen Non-Engine/Transmission Tailgate letter decal color delima
can someone tell me how many year model trucks might have a 53 block?
i suspect it was from 99-01,but not sure. I checked two more 01's one had 55 one had 56. I checked my nephew's 01 today and could'nt find any numbers on the block. on passenger side there was the letter A where the number usually is. so I assume it's ok. can someone clue me in here? thank you.
Hey Cubby how's life in S. Idaho treatin' you? Going to the dyno event May 1st? I plan to show up, hopefully I'll see you there.
The 53 blocks were predominately found in '98. 5, '99 and often 2000 trucks. I think a few '01s had them but not many. '99s seem to suffer from cracked blocks the most.
If you don't find any numbers that's a good thing, those are the best blocks of all since they came from the Mexico foundry and are known to be a harder material block (and you could say they are crack-proof).
So you looking to get into a 2nd Gen?? :D
thanks Vaughn, no I'm not, I'm working on an 01 w/53 block right now,putting everything in a non 53 block.
I won't be able the dyno day. other plans ya know thanks for the info
