JJ, There are as many opinions on this topic as there are on the TDR!
We've had various wood framed towables since '83 and like many out there we got into larger units over time.
I have always wanted an aluminum framed RV for its strength to take the abuse you'll give it over-the-road. I've heard all about the moisture etc. and wood framed has the same problem... only they rot. As you know ANY & ALL RV will form condensation, so the key factor is how well you VENT the unit! Especially when the RV is used in locals with temperature or humidity extremes, i. e. Fla. , winter camping, etc.
We finally purchased an aluminum framed unit (see sig. ) but this unit has a wood trussed roof. (We bought it off the floor, you can order it ALL aluminum construction. ) Personally, I prefer the aluminum for its strength and weight. It also makes for much better looking side walls. We have a brother-in-law who camped almost every weekend over the course of a year, winter and all, after about 8 years he had to get into floors and some walls. There was tremendous moisture in that unit (31') but the damage turned out to be mainly from the bath area!
The other thing I've notice about long wooden
TT's they can twist. Next time your behind a long TT (particularly the bumper hitch kind)
study the structure from the back to the front and you'll be surprised to see just how much these units bend and/or twist. I think this may occur in units over 28'. Another thing to be aware of, is cold weather camping produces tremendous amounts of moisture when an RV is lived in. Additionally, if a unit is leveled and supported at the corners a good frost heave can literally twist the unit bad enough that doors will not open or close! And it does NOT correct itself!
The key to RV longevity, wood or aluminum...
G O O D V E N T I L A T I O N !
I hope this helps?
White 2001, 3500, Auto,3:54 (soon to be 4:10),QC,2WD,LB,34' DBL slide Cardinal 5er
[This message has been edited by Tagalong (edited 02-23-2001). ]
