Ok jughead, I guess the reasons for the swap will help determine if you should do it or not. Are there any problems with your 5spd? After my 5th gear went out twice in 1 yr. , I did the swap in my '98 and love it. Very easy and straightforward, Blumenthal in OK has the entire kit for $3500. That is a new transmission, install kit (just a shift linkage ext for t-case and b/u light ext. ) flywheel for 13" clutch, and new Southbend clutch. Be sure you have access to a lift and a good transmission jack as the 6er is VERY heavy. I went ahead and put new u-joints in my driveshafts while I was having them sized for the 6 spd. I think it was about $250 to get them sized and new u-joints. So its up to you, I could've fixed my 5spd with a new mainshaft and rebuild the tanny while I was at it, I needed a new clutch any how (i was on the phone ordering a new one when my 5th gear wnt out again). I was lookin at about $2500 for all this done right with a Southbend clutch, So I chose the 6er for $3500 and love it, would do it again in a heartbeat.
