This is my '99 3500. This transmission has been rebuilt at 95K (5th gear nut backed off) and 155K (leaking fluid into clutch due to metal destruction of bearings - from defective aftermarket rear case). This latest failure was at 177K, 12K on transmission after last full rebuild. The 5th gear self-destructed suddenly.
Failure occurred at the end of a 3500 mile trip towing our camper. I am below the GCWR at 19600#s combined wt, only use lowest power setting on the SMARTY, turn the Edge Comp off, and stay at the speed limits. I do tow in 5th gear, but don't allow the RPM's to drop below 1700 without downshifting.
What have others done to keep their 5spd transmissions alive? I cannot justify spending $$$ on upgrading the transmission to a 6spd to tow 4 -5 times per year, on a truck this old.
Jeff
Jeff
