What has been the experince with the HD 5spd stock transmission. I am staring to get a rattle (teeth overlay noise) at low rpm higher torque combos. Worst is 2nd gear below 1100 rpms. Evidently the stock transmission has a couple of bearings that are caged in plastic and can not handle the heat. I have been told that it is most likely the bearing between 3rd-4th gear. It still shifts fine, I plan to drive it until she's done, but not sure how long that will be. Any experience or suggestions would be appreciated.
