Engine/Transmission (1994 - 1998) 5th gear ratio ?
2nd Gen Non-Engine/Transmission Exhauast
Engine/Transmission (1998.5 - 2002) BD TowPro
Don't think so. Based on the replies in your other thread, the auto looks to be taller gearing in 5th/od. My driving on the highway shows the following (confirmed on the GPS to within 0. 1 mph ): 55 mph = 1500 rpm, 65 mph = 1750 rpm, 75 mph = 2000 rpm, 85 mph = 2250 rpm. These are easiest to see because they fall directly on a guage marker line. The 60, 70, and 80 figures are right in between.
5th gear on an nv4500 is 0. 75:1.
4th gear on a 47 rh/re is 0. 69:1.
6th gear on an NM5600 is 0. 73:1.
Hope that helps,
Jeff
BTW, closer to 1:1 means geared lower. 0. 69 is a higher gear than 0. 75.
