5th wheel hitch and Rhino liners
Gauge pod from Genos
Napa Switch Conection for EBrake
Could someone who has a 5th wheel hitch and a spray in liner help me? If you put in a spray in box liner and then a 5th wheel hitch, do you need to cut out the liner for the hitch? Or can you install the hitch over the liner. Thanks
Randy Richmond, 98. 5 24 valve, 2500, 5 speed, 4x4, 3. 54, LB, QC, Van Aaken CPC, PacBrake, Walker flowthru muffler, Amsoil, running boards, Leer Shell, Metalic Red.
The hitch goes over the spray in liner. The best way though is to have all of the holes drilled for the hitch and then have the liner sprayed. That way you are not drilling through the liner. When they spray the liner, it will cover the bare metal from drilling. Looks great this way too.
Rick G - Phoeniz, AZ
99 2500 QC LB 4X4 5-speed
3. 54 LSD, E-brake,
ISSPRO Boost & EGT gauges(pre-turbo)
285/75 16 BFG AT on AR Atlas,Hadley Air Horns, Hitchhiker 33ft 5er triple slide
Randy, I had Rhino Liner put in my dually about 3 years ago and then put my hitch in over the liner. I have gone about 15k miles towing my trailer and have had NO PROBLEMS.
Walt
91 D350,New style BD Brake,Gear Vendors O/U Drive,Gauges-Pyro,boost,tach,trans,rearend,brake,
Airbag rear,Transfer flow tool/tank, Exh. sys,Rino lined bed, Alcoa Mags,SS runningboards.
16cm.
Thanks guys for the info.
Randy I have Line-x with 5th wheel hitch. I had the hitch in for about a year before having it sprayed. I removed the hitch to have it sprayed. You will have to redrill the holes. The liner doesn't completely fill the holes but fills them enough that bolts won't go thru.
PS: It looks great. Get a lot of complements.
Northport,AL. 1999 2500 quad cab, driftwood, 5 speed ISB. Boost and Pyro gauges. Line-x.
Amateur extra W4XH
Had hitch in truck before I got Line-X liner. Removed hitch and took rails in with the truck and they sprayed them too. As above, had to clean out the holes, also had to remove a little of the Line-X material from the rails where the hitch sits. I bought a can of spray liner and coated the bolts after I put the rails back in. Have had liner over a year and am very pleased. bg
White 99 3500, QC, 3:55, auto. most options except leather, Line-X bed liner, fiberglass running boards Ranco 9000s, bug shield and window vents, black vented 5th wheel tailgate, aluminum tool box, 100 gal. aux. fuel tank not mounted yet.
Ive got a Una-Goose, the ball comes out and the safety chain hooks come off. . there is one 4" hole in the bed where it all comes through. I had it rhino lined without a problem.
1996 2500 regular cab,long bed, 4x4, 5 speed, Rhino Liner
Stock plate must have slid forward when I hit the brakes
-- email address removed -- , Great Lakes TDR
PURDUE STUDENT  GO
BOILERS
Dodge Makes it
Cummins Shakes it
