TDR Issue 35 has an excellent article by Jim Anderson about GAWR, GVWR, GCWR etc, etc. But he also says in the article to put the king pin right over the rear axle. The idea being that the heavy cummins engine already puts the front axle near its GAWR and you don't need any more weight distributed up front by putting the king pin ahead of the rear axle.
That being said, sometimes it can't be helped depending upon the make/model hitch that you're putting in. Sometimes the combination of the of the hitch configuration and the location of the bed cross rails dictates where the king pin will be relative to the axle.
