I do not have anything to compare it to as this is my first 5th wheel, but I like the features and the hitch seems to be very nice quality, it carries a 7 year warrantee instead of the standard Reese 5 year. It leaves 4 holes in the bed, I have a rubber bed mat and I cut it out for the 4 holes so I can use it with the hitch in. The hardest part was fishing the bolts through the frame for the underbed mounting system. You have to drill the 4 holes in the bed which are 2. 5" in diameter and 4 holes in the frame that are 21/32". The holes in the frame meet the Dodge guildlines for drilling in the frame, total hitch install took me about 6 hours. I have a bunch of pictures, let me know if you want to see anything in particular. Interestly I bought the hitch from a online place with free shipping, I had the hitch in 2 days, but they sent me the basic 18K non slide, when I called them they then sent me the slide and did not want the parts from the non slide back. So I have all the parts to either use it as a slide or as a stationary, the head is the same but the base and side plates are different. The cost for the slide with the Dodge mount was $1080. The place where I bought my trailer wanted $1500 and would not budge, worked out better for me as it showed up at my door and I did not have to drive an hour to the trailer place to pick it up. I was on the fence about getting either the 18K or the 16K, I ended up with the 18K for the left right move ability, I have watched the trailer when I tow and it moves a little on bumps or with wind currents so I think it is worth it as none of that movement is transfered back to the truck.
